How to clean up photo?
I have old pictures which I scanned and found out, that there is a lot of dirt and dust particles on it.
How can I erase these dirt and make them undetectable?
Hi Abu Sabaya,
There are various ways to retouch images taken from old photos. Let’s tackle several ways to do so. In the end, you will have to decide which method works best for you.
You can delete easily by using the spot healing tool.
This tool is specifically useful in cleaning images from dirt and dust. Simply select the Spot healing tool and click it to the dirt or dust.
To make it look good even better, try to resize the brush size to a little bit bigger than the dirt.
Usually if the brush size is bigger, it tends to make the result noticeable as they includes large area from its surrounding area.
Use the Clone Stamp Tool while selecting an area that is close enough to the dirty spot you want to clean up.
Click on target , let go of ALT, then click over the spot.
This should replace the spot and clean it with the area you ALT clicked.
Okay. I have tried it already.
Sometimes it looks clear that you added a new change.
How can I fix this?
You can change the opacity of the clone tool.
Lessen the opacity to your liking and also try to select the source of your clone tool similar to what you intend the result will be.
Cloning to another layer can help, this in order to make the new dots to be editable.
Like changing its blending option, opacity as well as levels.
Thanks a lot you guys.
These really help!
I am very excited to try these new tips you gave me!
Good day to you Abu Sabaya,
I have been using Adobe Photoshop for 5 years and I encounter a lot of job by cleaning up of old/new photos. So here's what I do, if the photo is too much old, I use the brush tool, but be careful some brushes has different boldness and lightness when using it. You better first take a good look at the photo, if it's too light adjust the brightness to low, if the photo is too dark you adjust it high, in this case you will clearly see what you need to repair or not to be repaired.
After that you start using the brush tool, using the correct color of the original image that you've been repairing, to get the exact color of the image use the "eye dropper tool", this tool can replicate any kind of color that you wanted to use by not setting the RGB/CYMK color setting.
After you've done doing that, it's time to go back to the brush tool, when you see the spot you wanted to be remove use the brush with the correct color to the correct position nice and easy click on the mouse to paint it from a new layer, remember the original image shouldn't be touched, you have to do the editing from another layer or to the duplicate of the original image .
Or you can also hold down the mouse button and stroke slowly up or down, after you done this repainting or the damage spot, to be more look natural try adjusting the "opacity" of the layer where you paint the brush, this will give you more natural looking look of the paint color.
You can also use the "dodge and burn tool" to darken or lighten the paint color you've made, it can also make a shadow effect for the angles or shaded part of the image if you want to take it to next step to be more realistic.
Lastly the "clone stamp tool", this tool has the power to clone any part of the image where you point, just hold "Ctrl" and hover the mouse where the part of the image you want to copy, then press the button to part you wanted it to be copied and there you go, just make sure the to lower the density and the size of the clone stamp by clicking the right mouse button to the layer of your image.
Just make sure you're having fun trying my technique to have good results.
Cheers and Good Luck.
There are various ways of retouching images.
Among those, I will tell you about one of them, which is Adobe Photoshop.
Follow this process:
1. Open the image file you wish to correct in Photoshop Elements by clicking the "File" menu and choosing "Open." Find the image file in the navigator window, click it, and then press "Open."
2. Copy the "Background" layer by dragging the layer in the layer pane to the "Create a new layer" button. This will duplicate the image so that there are two layers with the same image. The top layer will be automatically named "Background copy."
3. Click on the bottom “Background layer.”
4. Access the "Filter" menu and choose "Noise" and then "Dust and Scratches." Move the Radius slider to the right until the dust spots disappear. Do not be anxious about the effects on the rest of the image at this stage. Click "OK."
5. Click on the top layer to make it the active layer.
6. Choose the "Eraser" tool and set the "Hardness" to "0" percent. Drag your cursor over the areas of your image that has dust particles. This will erase the top, dusty layer and let the bottom, corrected layer show through.
7. Merge the layers by clicking on the "Merge" option from the "Layers" menu.
That's all.
Hi
There is a Techyv video which one will be also helpful regarding on your issue. Watch the video and remove your prolem easily.
