How to clean registry with hitachi format utility for startup?
I need your help. I want to clean registry with hitachi format utility for startup. How can I do it? Please, tell me in details.
Thanks
Thanks
hi,
 1.  click start->controlpanel->system&security->Administrative tools->then double click on the computer management icon.If you have been set an password enter the password and click ok.
2.After opening the Disk management  click storage.Right click on storage select hitachi life storage and click format.
Hitachi Format Utility is an inbuilt application provided with Hitachi products. With this application, you can Format your computer, clean up your Registry, clean temporary files etc.
To clean your Registry, you just need to open the Hitachi application and there you will have the option "Clean/optimize registry". You can click on that option to clean your registry. I suggest you to create a system restore point before cleaning up your registry to avoid system crashes.
Just in case the Hitachi format utility is not working fine on your computer, try downloading a free version of the Registry cleaner onto your computer. Alternatively you can clean your registry with Antivirus program such as Norton, McAfee, Panda, NOD32 etc.
Thanks and regards,
Skarbos Jay.
