andrew word
30 points
Posted on - 05/09/2013
Good Day Experts!
Do you know how to clean registry with VB6 applications? Is there really an application in VB which can clean the registry? Can anyone please help me? What are the things that I need to consider before cleaning the registry? Can you provide a sample code which can clean the registry by removing all the VB6 DLL files? If you have an existing sample application, then please share with us. If you are using third party softwares, do you know where to find a free application? It would be very helpful if you can share your expertise and knowledge.
Thank you for sharing.
How to Clean Registry with Vb6 Applications?
Hi Andrew Word,
CCleaner is one of the known cleaner software. The image below is the screenshot of CCLEANER software.
Crap Cleaner is the former name of CCleaner and it was developed by Pinform. CCleaner can remove useless files including Microsoft apps. CCleaner is free to download and windows utility. If you want to download visit. www.piriform.com/ccleaner‎
CCleaner will clean your registry in Firefox, Chrome, Internet Explorer. This will easily clean the temporary files and obsolete registry keys
Hi Andrew Word,
I can see that you are trying to create an application that will clean the unwanted registry on your system, it may be complex so I've searched the source code for you, it comes from codeproject.com, a website for open source codes to help programmers like us,
Below, I will attach the link that you are trying to find, credits Jay7093 for sharing us this codes Link Here
