fayette25
Posted on - 10/02/2011
Why does other viruses that we obtained it can only be clean if we reformat the computer and re-install the OS(Operating System) and all the applications that we install in the computer in order to clean or to get rid the virus of the computer system?
Peter123
How to clean a virus that we obtain in the internet
Hi!
Viruses are specially designed softwares to harm our computers' software and in some extent they can harm our hardware too. They are so technically programmed that they affect directly the registry of our operating system. As you know anyy programme which is installed by us make an entry in the operating system registry. Anti virus softwares recognize those entries and make changes to the operating system registry which is certainly irrepairable. Once they reside in our computer even for a short while and get access to our registry the only solution remains is to format our hard drive and reinstall the operating system and other installed softwares. I suggest you to always use an updated version of an antivirus software to keep your computer protected.
Hope it helps.
Hi dude, There are lots of good antivirus available in market, you no need to reinstall your PC in case u attacked by a virus. Just some steps of you, can take away virus attacked in your system. First Always keep good antivirus in system and do regular update it from internet.. Do regular scanning of your system. Use registered version of Antivirus software.
