Moose Lodge
20 points
Posted on - 01/13/2012
There is a problem that when open internet explorer, the home page shows with random words that are underlined and it showed no apparent reason for this. When clicked on a new browser it opens with `search miracle’ giving changes to homepage.
Why the internet explorer home page is with some underlined words and how could I delete search miracle which gives changes to homepage?
How to clear changes on home page of internet explorer
To change your home page in internet explorer:
INTERNET EXPLORER 5&6:
1. Start internet explorer.
2. On the tool menu,click internet options.
3. Click the general tab.
4. In the address box, type the web page address that you want for your home page.
NOTE: If you want the page that you are currently viewing Internet explorer to be your home page, click the current.
5. Click ok.
Hello moose,
If I am not wrong than either updated your internet explorer or installed an add-ons in your browser. If so than just uninstall the add-ons and disable that from the tools, select internet option, than select the programs tab and click on the manage add-ons than just uncheck that add-ons.
Also change the home page settings and clean cache and cookies from the internet history.
In the mean time must scan the whole computer and make sure that there is no virus affected your machine.
Thank you,
Riley weaver
