How to clear the History entries in Internet Explorer
As you browse the Internet, each of the items you view are saved locally on your hard disk drive. This helps web pages you visit frequently load faster by loading the files from your hard disk drive instead of having to download the web page again. To conserve hard disk drive space or to help keep their Internet browsing private, users may find it necessary to delete their Internet History, below is how doing this.
Mozilla Firefox users
Viewing History
Press Ctrl + H to open the left-side history bar.
Or
Click History at the top of the window.
Or
Users using earlier versions of Mozilla Firefox can also view their history by clicking "Go" and clicking "History."
Deleting History
Press CTRL + Shift + DEL to open the Clear All History window.
Or
Mozilla Firefox users can clear their history by clicking the "Tools" menu, "Options", clicking the "Privacy" button, and under "History" click the "Clear" or "Clear Now" button.
If you don't see the File, Edit, View menu press the Alt key.
Hello Kamrul,
There are many ways on how you can clear the history of Internet Explorer whether a version is old or new. The standard procedures in clearing history directly go to your control panel then double click internet option. In General tab locate Browsing history then click on Delete tab and select Delete history or you can click Delete all. Delete all well remove Temporary internet files, Cookies, History, Form Data, and Passwords. In Internet Explorer browser select Tools menu then click on Internet Option, as you see it same with the first procedure we had.
In Mozilla Firefox version 3.6.21
To clear history directly open Mozilla browser click on Tools menu then click Clear Recent History. As you can see there are details, just uncheck Cookies, Cache, Active Logins and Site Preferences and click Clear Now then restart your Mozilla Firefox.
Internet Explorer saved a lot of histories, cookies, forms data, passwords, temporary Internet files, InPrivate Filtering data and Preserved Favorites website data.
These are so called bits of data saved in your Internet Explorer browser for faster download once you want to re-visit the sites.
However, browser has this limitations when saving data. It slows down the browser and sometimes it's the cause of the browser to freeze.
There are ways to delete the History in Internet Explorer. There is a shortcut way to clear all those out or you can do the normal ways.
Press Ctrl + Shift + Delete at the same time. A windows will pop-up and it gives you options to delete history by checking on the box on each category. Then click on the Delete all or Delete button.
Another steps to clear History
Open Internet Explorer then Tools
Select Internet Options
Click on the Delete button on Browsing history area
Check all the boxes or History box only
Push the Delete button
This then clear all the browsing history
