Kyle Berry
30 points
Posted on - 09/28/2012
Hello, how to clear magento products? Is there a way to delete all the products in the magento, an ecommerce software that will help us build a business through the internet. I want to delete some products but I don’t know how to do it. Can you guide me, you suggestions and ideas are very important and is a big help? Thank you
How to clear magento products?
It is easy to delete product from magneto. Only follow this procedure:
Open catalog then manage products. Here you will find the products you have listed. Choose the products by checkbox those you want to delete. Now click on action and then select delete. Finally submit for deleting. You are done.
You may visit
The LINK for more instructions.
Hi Kyle,
Yes, you can delete the whole products information by using a few command. After giving the command, it will clear the whole information automatically which is related to products. Please go to this blog http://www.phptechi.com/how-to-delete-all-products-in-magento.html to know more about your enquiry. Thanks.
