How to clear WRKPRB Entries
How can I clear many WRKPRB entries created due to fax line failures?
I am already using Option 8, Option 20 to close & Option 4 to delete.
What are the steps to resolve it?
This command shows a list containing machine detected problems that were opened due to the message, CPF6788, having been sent to the system operator message queue and for which a problem analysis was done.
The problem analysis was done to determine the resource name of the device suspected of failure, which in this case is device, TAP01. The list of problems includes user-detected problems.
To get the user-detected problems, the user specified the resource name and message identifier by using the Analyze Problem (ANZPRB) command.
I understand that you are having a difficulty in clearing WRKPRB entries.
I can give specific instructions on how to resolve your issue.
Here are the steps to do it:
1) Try the command DLTPRB​. It will delete all problems from the problem logs. If it fails to do so, go to the next step.
2) Type this command CLRPFM QASXPROB and press enter. That should do the trick.
