How to clone a cricket cell phone to make calls?
How to clone a cricket cell phone to make calls? Do I need two identical phones or any cheap phone will work for cloning?
Hello Jair,
Carl
You can only clone your phone if you have the cricket ESN number. Then you have to flash the phone with Cricket firmware. If Cricket doesn't sell this phone, then you can't even flash it with Cricket firmware because there isn't firmware for any phones that they don't sell. Each mobile phone has its Electronic Serial number or ESN.
You can find out more from here-
http://ww1.levoltz.com/?sub1=c2bfb000-f485-11e7-9c8f-00b6060055ba
Hope that will work for you.
Thank you guys. Actually while trying to solve my problem, I have visited many websites for a remedy but their solutions are hard for me and so I can not understand their techniques. Carl Jack, your solution is superb and very easy for me. By following your method, now I am able to use it. Well done Cal Jack.
