How is cloud computing different from grid and thin client?
Hi All,
Can anyone explain this in detail
Hi All,
Cloud computing can accommodate up to large capacity with less investment of creating new infrastructure, workforce cost and legal matters for licensing. It gives benefits mostly to medium-size client that wanted to outsource business somewhere else. It save time, money and efforts because instead of creating large data centers for storage; then why use this cloud computing that can carry the same load capacity but less spending.
While Grid computing gives on-demand resource provisioning. This depends on the type of users that will use grid computing. A maintenance is needed if you are an Administrator because you need to run the application and provides updates in the cloud. However, a plain user will only manage his thing but usually doesn't care of how to run the system.
In cloud computing, companies can store there information on the internet which is referred to as ‘cloud’ and therefore they pay only for what they use. These cuts on the amount the company would have spent on  buying more computers and other computing equipment that assist in storage of information, especially for small and medium-sized companies that require upgrading of their systems from time to time due to increase in the amount of data stored. The cost of buying hardware and software is cut when cloud computing is used.
Grid computing on the other hand involves the use many computers at the same time for the purpose of solving a single problem. The computers are meant to share resources so that to solve problems collaboratively. The computers on a grid may be located far away from each but on a network and they are also loosely coupled.
In thin client computing, users on the network gain access to their information via a network connection to a server. Users access information via the desktop, and the major disadvantage of this is that when the server goes down, then all the users on the network are affected.
