A large number of people now run their business by cloud computing. Is it trustworthy? How cloud computing helps in disaster recovery?
Exactly cloud computing is a very good technology.
1. This technology does well in its work to narrate the cloud computing skills at its best.
2. Replicated copy of data lies at the master and the slave computers.
3. Data resides and are updated by many means so that many computers share the task.
4. The network forms a cloud so that the failure of one system will not diminish the entire network.
5. Some times system crash occur still the data is always kept somewhere in some other system that does the function.
6. The whole network is a collective effort of many systems cooperating their task.
If you have doubts on the reliability and security of cloud computing then you should learn the benefits that you can get. Here are the 10 benefits of cloud computing:
Enhanced flexibility – you can instantly change direction without having any financial or “people” problems.
Globalize your workforce on the cheap – people anywhere in the world can access the cloud as long as they have an internet connection.
Reduce capital costs – you don’t need to spend more money to buy new hardware, application and especially the licensing fees for each of the programs you’ll be using.
Achieve economies of scale – you can expect a boost in the productivity and or output with only fewer people. Your expense for every product, unit, or project plunges down.
Improve accessibility – you can access and check the status of the project anytime and anywhere making your life so much easier.
Minimize licensing new software – you can extend and add as much workforce as you want without the need of purchasing expensive programs and licenses.
Reduce spending on technology infrastructure – you can sustain easy access to the information with only very minimal spending. You can pay as you go depending on your demand like for example weekly, quarterly, or maybe yearly.
Streamline processes – you can expect more work gets done in such a short time with only very few people.
Monitor projects more effectively – you can keep within your budget and upfront of your completion cycle times.
Less personnel training is needed – it will only take you fewer people to do extra work on a cloud with only minimum learning curve on software and hardware issues.
