How to code Auto mouse color function in Java
I'm thinking of a Java program that would recognize the text on the screen as the cursor hovers. By that, the background color would automatically change based on the text. For example, as the mouse points to text "black", the background would be black. How could I do this auto mouse color function?
Best Answer by Shifflett Laurel
Answered By 0 points N/A #194911
Hellow Crewe Bob,
My aim is to give you the basic idea of MouseOver to change anything by an example
I have created input files consisting of three fields
Height                    Width              Text_to_Show
50                           100                  Shifflett
I am constructing an exclusive function ‘GradientPaint’ by ‘new’ keyword.When the function create two
Rectangles and a user moves the mouse over the rectangle then the  text message attached to it:- Like for  row 50,100  will be seen as  "Shifflett".
for(int i=0; i<myarraylist.size(); i++)
               Coloring fc = myarraylist.get(i);
GradientPaint gpi = new GradientPaint(0, 0,c.getColor() , 0, 20, Color.white, true
                                              g2d.setPaint(gpi);
                                              g2d.drawRect(fc.value1, 29, fc.mywidth, 83);
                                              g2d.fillRect(fc.value1, 29, fc.mywidth, 83);
                                              fc.addMouseMotionListener(this);
                                              fc.addMouseListener(this);
Thanking you
Shifflett Laurel
Answered By 5 points N/A #194910
Hello Bob,
Here is javascript code for changing the background color with mouse over the text.
<script language="JavaScript">
function changeBGC(color)
document.bgColor = color;
</script>
<a href="#" onMouseOver="javascript:changeBGC('# 000000')">Black</a>
I hope that this script will help you.
Answered By 10 points N/A #194909
I provide a Java code for you that can help you to click on the submit button then it gets executed.
This code includes the getPixel Color method and pass the x and y coordinate values as argument and this will return the rgb color information on that particular coordinate location.
The Java code is attached.
Thanking you
Franke Mary
