Hello Martha,
I am going to show you a simple multi-threaded Java HTTP Proxy Server.
This is just a sample and not fully functional for every application. It’s very simple and works fine for HTTP GET requests, but it is not coded to handle properly neither HTTP POST requests nor any other HTTP methods. This is just an example to show how simple it is to proxy requests. This one records the URL of all requests those are passed through it.
I am going to show you two codes. The code give below is a multithreaded server. The code is as follow:
Package proxy;
import java.net.*;
import java.io.*;
public class ProxyServer {
public static void main(String[] args) throws IOException {
ServerSocket serverSocket = null;
boolean listening = true;
int port = 10000; //default
try {
port = Integer.parseInt(args[0]);
} catch (Exception e) {
//ignore me
try {
serverSocket = new ServerSocket(port);
System.out.println("Started on: " + port);
} catch (IOException e) {
System.err.println("Could not listen on port: " + args[0]);
System.exit(-1);
while (listening) {
new ProxyThread(serverSocket.accept()).start();
serverSocket.close();
The above code just starts up the proxy server on a given port, takes in an HTTP request, and spawns off the request to a new thread passing the socket to the thread, and starts that thread on the request.
The following second code is a thread that starts up, and then receives the incoming request from the client. It is as follow:
package proxy;
import java.net.*;
import java.io.*;
import java.util.*;
public class ProxyThread extends Thread {
private Socket socket = null;
private static final int BUFFER_SIZE = 32768;
public ProxyThread(Socket socket) {
super("ProxyThread");
this.socket = socket;
public void run() {
//get input from user
//send request to server
//get response from server
//send response to user
try {
DataOutputStream out =new DataOutputStream(socket.getOutputStream());
BufferedReader in = new BufferedReader(new InputStreamReader(socket.getInputStream()));
String inputLine, outputLine;
int cnt = 0;
String urlToCall = "";
//begin get request from client
while ((inputLine = in.readLine()) != null) {
try {
StringTokenizer tok = new StringTokenizer(inputLine);
tok.nextToken();
break;
//parse the first line of the request to find the url
if (cnt == 0) {
String[] tokens = inputLine.split(" ");
urlToCall = tokens[1];
//can redirect this to output log
System.out.println("Request for : " + urlToCall);
cnt++;
//end get request from client
BufferedReader rd = null;
try {
//System.out.println("sending request//to real server for url: " // + urlToCall);
//begin send request to server, get response from server
URL url = new URL(urlToCall);
URLConnection conn = url.openConnection();
conn.setDoInput(true);
//not doing HTTP posts
conn.setDoOutput(false);
//System.out.println("Type is: "//+ conn.getContentType());
//System.out.println("content length: "//+ conn.getContentLength());
//System.out.println("allowed user interaction: "//+ conn.getAllowUserInteraction());
//System.out.println("content encoding: "//+ conn.getContentEncoding());
//System.out.println("content type: "//+ conn.getContentType());
// Get the response
InputStream is = null;
HttpURLConnection huc = (HttpURLConnection)conn;
if (conn.getContentLength() > 0) {
try {
is = conn.getInputStream();
rd = new BufferedReader(new InputStreamReader(is));
} catch (IOException ios) {
System.out.println("********* IO EXCEPTION **********: " + ios);
//end send request to server, get response from server
//begin send response to client
byte by[] = new byte[ BUFFER_SIZE ];
int index = is.read( by, 0, BUFFER_SIZE );
while ( index != -1 )
out.write( by, 0, index );
out.flush();
//end send response to client
//can redirect this to error log
System.err.println("Encountered exception: " + e);
//encountered error – just send nothing back, so
//processing can continue
out.writeBytes("");
//close out all resources
if (rd != null) {
rd.close();
if (out != null) {
out.close();
if (in != null) {
in.close();
if (socket != null) {
socket.close();
e.printStackTrace();
Hope it was helpful for you…
