morhumjibon
Posted on - 08/19/2012
Numerous tmp reader programs are seen available over the internet. I have tried only a few. They often seek a license to complete the exact action what I want. Is there any way to overcome this without purchasing a license?
How to collect absolutely free tmp reader programs
You can always open Temp files when using a Notepad, or depending on the file type because oftentimes temp files is not readable. To open a .tmp file just right-click the file that you want to open.
Select Open and then select Notepad on the program list. Click OK. You cannot delete a specific Temporary files if you force quit your Windows.
FreeFileViewer can open your temporary file. This is a free tool.
Temporary files are not always stored as text files because sometimes they are in binary format. You are lucky if the temp file is a text file because you can open it using Notepad. But if the temp file is in binary then there is no way you can open it because the content is in binary format and you will only get symbols if you use an incompatible program.
If you want to open a temp file but don’t know how or you don’t have a program that can open it then using FileViewPro will help you achieve it. Download FileViewPro 2014 then install it on your computer. This latest version supports Windows 2000, Windows XP, Windows Vista, and Windows 7. This program lets you open any types of files like audio, picture, document, video, and others.
