Hello Experts,
How to combine DLL and exe into one file? Is there a way that we can combine two kinds of format into one or merge them together for example a DLL file and .exe file? If there is some software that will allow this kind of process please let me know and tell me more about it. Thank you.
How to combine dll and exe into one file?
Hi Jeffrey,
If you want to combine .Net dll’s and exe into one .exe or .dll file then you can use "ILMerge". This is a free tool for merging .exe and .dll into single exe or dll file. Download this tool from Microsoft site. This is a console tool as well as you can automate it with visual studio, so read the documentation for performing the required task.
Thank you.
Hi Jeffrey!
Combining DLL and EXE into one file you must first download a free tool which performs this kind of task. I will share with you the link I found which help and teach you to manage this task. Just read the instructions carefully to have a right access and a successful installation.
Link:Â http://www.developerfusion.com/code/4504/merge-an-exe-and-a-dll-into-one-exe/
Thank You!
