How to combine pictures into one- Steps to follow.
I want to gift a photo frame to my younger sister. I am planning to give her my well designed photo of her and me. I want to combine the two photos. How to combine pictures into one?
Step 1: Open Adobe Photoshop CS5.
Step 2: Click New after clicking on File. It will open the board. You need to decide the height and width for your pictures.
Step 3: After your canvas is open, select File and then Place.
Step 4: You will get a new window through a pop up. Choose the file that you want to combine.
Step 5: Place the file accordingly. You can adjust the size as well.
Step 6: After deciding with it, right click on the picture. There will be several options. Choose Place to keep an image as you have decided and Cancel to remove a picture.
Step 7: Now select the second image to combine with the first one. You can also change the adjustment and size of the picture.
Step 8: Now you can save the file.
