Hi i want to know is there any way to combine a split rmvb video that i import in videostudio. I am very keen and eager to know about it so please give me the tutorials as soon as possible. Thanks.
How to combine a split rmvb video that i import in videostudio
Yes there are many ways to combine a spit rmvb files. You can use Boilsoft Video Joiner.
So first download Boilsoft Video Joiner and install it.
Then in menu click on ADD FILE.
Select all source files which you want to combine.
Mark them all and arrange them in your required order.
Below select the output file location and output format.
Addition options can be edited like video frame rate, size and quality.
Then press Joining button.
It will combine all your split parts into one rmvb video.
2nd way
You can change rvmb format into .vob by Total video converter (free available)
Then download VOBMERGE 2.5 (free available) and combine your split files.
You can use them in .vob or if not then convert it back into rmvb format buy total video converter.
But I will prefer use 1ST method.
