How come some of the application components in Photoshop are missing?
I tried to launch Adobe Photoshop application pretty well, but the error has rightly appeared.
Adobe Photoshop
Some of the application components are
missing from the Application directory,
Please reinstall the application.
                      OK
What must I do to resolve this? I badly need this in making my projects but if I can’t find a way to this, I really don’t know of other best options to do.
Can you please tell me if there is?
Or do I have to reinstall it?
Hello
I seams that your Photoshop application ran in to a problem during shut down of the application or in correct closing of the application.
· If you have a setup file then try to repair the application.
· If the repair doesn’t work try to reinstall the software.
· Check whether your license is of full version or limited period.
Hello Chesley Sielaff,
There can be a number of reasons why you are seeing this error message, please try the following and check if the issue is resolved:
– Is there an online update available for you software? If this is so, please update it.
– It might be the case that the software files have been corrupted due to force closure or sudden restart of your computer. Go to Control Panel, click on Programs and Features and double click on this software. If there is an option to repair, do it, otherwise reinstall the software.
– Have you purchased the full version of the software from the official source? If not, do so.
