How To Compare Two Columns In Excel For Matches?
I have entered some data on my excel sheet, and I am afraid I have Written some duplicate values in two different attributes. Can I compare two columns in excel for matches?
Yes, you can compare the columns in excel to find out any duplicate value by two methods:
i. Using a formula
• Open Excel, and in anew sheet, fill the following data:
A1: 1 C1:1
A2: 2 C2:2
A3: 3 C3:3
A4: 4 C4:4
Leave the column B empty.
Now, type the following formula in B1 address bar:
=IF(ISERROR(MATCH(A1,$C$1:$C$5,0)).””A1)
Then, select all cells from B1 to B5.
Finally, Click on fill in the editing pane, and then click on
Down.
ii. Using Visual Basic macro
• Open Excel, then press Alt+F11 to start visual basic
• Click on Insert, and then Module
• Now, enter the following code:
• Now, press Alt+F11 again to return to Excel
• Enter the data in Column A and C same as in method 1.
• Select A1 to A5
• Now, go to macros and click on Find_Matches, then click on Run.
You can see the duplicate values in column B.
Notifications
