How to compile mdb file to exe file ?
Hi Experts
I am using MS Access 2007. I want to covert.mdb file to .exe. Can anyone help me how to  compile mdb file to exe file?
Hi Experts
Hi Alexander,
No you can’t convert .mdb file to .exe file. If you try to convert .mdb file to .exe file you will destroy all the data stored in the database. Reason for this is that there is no compiler available in access and at the same time mdb file is data and the interface.
Hello Alexander,
This is an alternate solution to your requirement. Instead of worrying with MS Access you can convert mdb file into exe with the help of MDE Compiler. It's very useful software that allows you to create an exe file from your Database Application. It contains many features like Custom Icon image, Custom exe file version information, Custom run command and command line parameters and many more.
Use the following link to download the MDE Compiler.
Thank you.
Rubi Sharlene
