maxor tamu
Posted on - 05/20/2013
Greetings! I was wondering if there is an easy way to delete 3gp converter? Please provide me some software or step-by-step process on how to delete 3gp converter. Please provide easy instruction since I am not a computer savvy. Thanks!
How to completely delete 3gp converter
Greetings,
The simplest way to delete 3GP converter is using windows program using add/remove program.Go to the start button and select all programs then look for the 3gp converter directory.it brings you a remove option which you click and brings you the setup wizard.Select next so that the converter displays the remove option and on clicking on it the uninstall process automatically begins.Incase any files are left uninstalled then download best uninstall tool ,run it and install it into your pc. Now click on the uninstall option and your 3gp converter will be permanently deleted from your pc
