How can I delete iMesh in my program file folder? Whenever I try deleting it, this message keeps on appearing,
"Cannot delete Browserconnection.dll: Access is denied. Make sure the disk is not full or write-protected and that the file is not currently in use."
I am sure that there are no other programs open whenever I am trying to delete it but, how come I am getting this message? Are there some other ways that you can suggest? I really wanted to get rid of iMesh in my folder. Please help. Thank you.
How to completely delete iMesh?
It's very simple dude. Just follow my direction. Don't try to remove it directly from program files.
Go to Control Panel and Select Uninstall a program.
Find " iMesh media bar " in the list and uninstall it.
After uninstallation is completed open Internet explorer.
Click Tools then go to Internet Options. Select "General" .
Set www.google.com as your homepage or select use blank.
Click the settings for " search " option.
Select iMesh and remove it.
Click OK to close the window.
If you are a user of firefox follow the instruction below :
Open firefox. Select "Tools" Then "Options" Click the "Main" Tab. Write a webpage that you want for homepage. Click "Ok" .
Restart Firefox. Now you have successfully removed "iMesh bar" from your computer. Use registry cleaner to clean registry.
