How to completely remove Norton through different methods?
To protect my computer form virus and malware, I was using Norton Antivirus Software. But I think now I don't need it. How to completely remove Norton?
Norton helps user to protect their information and provide security to it from malware, virus and other threats. If you don't need it then you can also remove it from your system.
Method 1- With the help of Norton Removal Tool.
Step 1: Download Norton and save it.
Step 2: For the Norton Removal Tool, run the .exe file.
Step 3: Select Next and to remove all Norton products follow on-screen prompts.
Step 4: Click Finish after removal is done and restart your computer.
Method 2- With the help of Control Panel in Windows.
Step 1: Select Control Panel after selecting Start.
Step 2: Choose “Add / Remove Programs.”
Step 3: Select the product which you want to remove and then click Remove.
Step 4: You can also choose Remove All to remove Norton and other products from your system.
Step 5: Restart your computer.
