How to completely uninstall AVG with the help of different methods?
To protect my computer form virus and malware, I was using Antivirus Guard. But I think now I don't need it. How to completely remove AVG?
AVG stands for antivirus guards. It provides several products such as AVG Internet Security that combines antivirus, Anti-Spam, Identity Protection, etc.
Method 1-
Step 1: Login as System Administrator.
Step 2: Click on Programs after clicking Windows Home.
Step 3: Enter a file name AVG.
Step 4: Scroll to the link Uninstall AVG.
Step 5: When you get "Please, keep me protected with AVG Security Toolbar and LinkScanner (recommended)", then uncheck it.
Method 2-
Step 1: Click Start then Settings and then Control Panel.
Step 2: Choose Add/Remove Program option.
Step 3: Find Microsoft Visual C++ 2008 – x86 9.0.30729.4148 and uninstall it.
Step 4: Select Yes to remove it.
Step 5: Reboot your computer.
