How to Compress A Large Number Of PDF Files
I have a large number of PDF file that I need to compress and send as email attachment. Could you kindly show me how I can have all these files compressed? What software do I need to use to achieve this? By how much would the size reduce after the compression?
Answered By 0 points N/A #190835
Hello. How are you?
I had the same problem but with the picture.
I used a software called WinRAR. Its a cool software with awesome option like shutdown after compression done. It can reduce files to  half of it , this program i advice you to use it. I hope that it will help you Jackly Donse. If you have got another such type of question ask me i will ask as fast as i can. Wish you will have your job done in easiest way.
