How to compress video files in Mac
Hi, I need to compress some video files to send via emails. I don't have any idea about compression. How to compress video files in mac? Please any one help me quickly.
Video compression on a Mac can be done using 3rd party software. One such example is MPEG Streamclip, which will let you convert a video into a compressed version by adjusting the size, quality, frames, and others.
Actually, Mac has its own simple version of a video compressor called iMovie, though this is more of a movie maker type that simply takes videos and converts into a format that takes less space.
Convert video with a lower bitrate. Compress will lead to quality loss. iSkysoft is a good toll for compressing video with good quality. Esle, if you got iMove then follow below steps:
Take Care
You can compress your videos using any normal compressor software. Here, in this techyv link, the tutorial is given with which you can compress any files and share them easily.
