How to config graphics fifa?
Please, I ask about config graphics FIFA and I want to know if I can play FIFA with Windows 7 without graphic card or not and how can do this? Thanks
After installing FIFA, start it. The game will configure it so as to optimize your system's resources. It will set the screen resolution to one that will enable you to play the game smoothly.
Depending on the integrated video chip on your motherboard, it can also turn off some advanced graphics options (such as anti-aliasing). You can however, go to "Settings" after launching the game, then go to "Video/graphics", then set the options as per your preferences, then save the settings.
Find out the Fifasetup.exe in your FIFA game folder. Open it and go to the game setting and from there select your preferred resolution. Most of people use lower resolution for better system performance.
While higher resolution gives clearer playing environment. If your computer has higher memory and processor you may higher resolution. Graphics card is necessary for this game.
