Hello experts
I have a simple question. How do I configure the Auto run Setting?
Where can I find the utility to set it up?
I want to be able to disable/enable this setting but I don't know where to find it.
Need your help.
How to configure Autorun settings
Configuring auto run setting or enable or disable auto run setting requires some thing.
To check the requirement and to learn enabling and disabling auto run USB or other portable disk.
Please visit this link : https://support.microsoft.com/en-us/help/967715/how-to-disable-the-autorun-functionality-in-windows. You can easily enable or disable auto run feature on Windows 7.
But it is always recommended that you should never enable auto run.
If you enable ,virus may cause your computer a damage. Procedure to enabling and disabling auto run on windows 7 :
Go to control panel from start menu. Click on Hardware and Sound > then on auto play> Put tick marks that you want to allow auto play.You can enable all too. Finally save. Disable:
Just the same way but just uncheck or pull out the tick mark.
Have a good luck.
