How to configure Clustering with failover in linux
What is clustering?
What is failover ? How to do clustering with failover between two RHEL Server?
How to set auto change clustering,failover ?
How to monitor?
Explain how to mount  FC SAN LUN in Cluster, failover Red hat server?
Explain with samples?
Answered By 0 points N/A #90096
Clusters is a group of independent computers that work together to increase the availability of application and services. Cluster servers are also known as nodes. If one node happens to fail the other will set in to continue with the provision of service. This action is what is known as failover. The best way to monitor clusters is by trying to create a rule that will quickly pick up the event from the cluster nodes. For the Red hat cluster you need to have entitlement for the software for you to be able to install and configure. You use configuring tools to specify the relation among the clusters.
