andrei
10 points
Posted on - 03/06/2012
Hello, guys,
We use two identical F-Secure messaging gateway servers but only one is used. The other server is used only when there is a system crash or automatic fail over of device. The two servers have different IP addresses, but they have identical configuration. My question is how do I configure Domino server to automatically route SMTP mail to backup server if standard server is down.
Thanks in advance.
How to configure Domino server to automatically route to backup
The solution for this is to install the TCP/IP on the stand-alone PC and modify the loopback interface if there is no network card installed on your system. And then setup the Domino server typically.
Assuming your stand-clone PC has a ntserver1 name, after locally running the Netscape or the MSIE, indicate the localhost to 127.0.0.1 or http://localhost.
You must have TCP/IP installed on the stand-alone PC; you should configure the loopback interface if you have no network card.
Configure the Domino server normally. When you run Netscape or MSIE locally, you can specify localhost, 127.0.0.1, or the system name like so: "http://localhost", "http://127.0.0.1", or "http://ntserver1" (assuming your stand-alone PC is named ntserver1).
