Hello Techyv, I would like to ask how to configure Gimp front panel online? Is there a possibility for this? If so, please tell me how. What are the steps needed for this? Please kindly give me your detailed explanation on the matter. I'm looking forward for your response. Thanks.
How to configure gimp front panel online?
Hi Roger,
There are a lot of editing functions you can do with GIMP, it has versions for Windows, OS X and Linux. It can also be used to convert images with different file format.
You can also create GIF and MPEG files just by using a plug in for animation. Now, given all those functionality I have found a link to check to other things you can create and edit with GIMP.
Just click the link here.
