How to configure Lenovo keyboard for windows 7?
I have Lenovo with windows 7 installed and was wondering if someone knows how to configure Lenovo keyboard for windows 7 to disable keyboard clicking sound. Any kind of help would be appreciated.
Hello Moss,
The following is the procedure you will use to disable the keyboard clicking sound for a Lenovo computer.
After that you should not be able to hear the keyboard sound when you type or press keys on your keyboard.
Hope this helps.
Carl
Hi!
Here I am to provide you with additional solution for you to remove that clicking sound.
First of all, you need to click on Control Panel option after opened the Computer icon. Then, go to the regional settings for more clear instruction.
Next, you should see many things that you can change including that clicking sound. Edit it.
Otherwise, you may try this option = firstly, try to right click on Admin after you opened the Keyboard Settings. Then, select the Keyboard Customizer. There you go, you might change that settings.
