How to configure mms settings for nokia x2?
How to configure mms settings for Nokia x2? Which network services are you using now?
You can automatically find MMS setting by calling customer care. Just save them and you can use MMS facility.
Thank You.
Follow the instructions :
Menu-Settings-Configuration-Personal settings-Options-Add new-Multimedia msg
Account name = "whatever you want"
Server address = mmsc."your server".com
Use pref. access pt. = NO
Access point settings:
Proxy = Enabled
Proxy address = 66.209.11.32
Proxy port = 8080
Bearer settings:
Packet data access pt. = wap."your server"
<Leave other settings default>
3) Default config. settings = Personal config.
4) Activate def. in all apps.
5) Menu-Messaging-More-Message settings-Multimedia messages-Configuration settings
6) Make sure Account is set to the new Multimedia msg entry that was added above
THANK YOU !!!!!
