How to configure no installation PLS player in Windows?
Hello Techyv members. I need help on how to configure no installation PLS player in windows media player.
How can I make this possible?
What are the steps needed for this kind of issue.
I welcome any recommendations and solutions offered by experts.
An overview about this issue would really be a great help.
Best Answer by Huffman Serafin
Answered By 0 points N/A #130526
Windows Media Player does not support PLS file playback.
You can either switch to another audio player that supports PLS like Winamp, VLC media player, or foobar2000, or use a program that can enable Windows Media player to play PLS files.
Such a program exists, and it can be found here.
Answered By 0 points N/A #198356
Hi RobertCBusch,
You can download video codec to support your request, I have one program that will help you out, it is the Combined Community Codec Pack, this software has almost all the video codec that can help you play all media files, download the CCCP and then install it and integrate it with media player classic or windows media player.
