Hello experts,
How to configure Nokia x2 01 MMS setting? Yesterday my friend sent an MMS to me with her picture attached on the file but until now I didn’t receive any MMS message when my mobile phone is supported. What would be the possible problem?
I need your help.
How to configure nokia x2 01 mms setting?
Please be sure that your friend has send you the file by using the mms service. And is that, then it is problem with your service provider of your phone. Please contact with your service provider and get the settings that required to send mms or receive from others . Then try again.
Thank you.
Hello Jayden,
There can be 2 reasons for not delivering the MMS to your phone. Your mobile service provider haven’t enable you to receive MMS or the MMS with the picture is too large.
Contact customer care of your service provider, and you can ask for MMS settings. After doing so if you still don’t receive MMS message go for the next step.
Ask your friend to compress the image file or lower its quality and resend.
Hope this will resolve your problem.
