Hello experts,
How to configure NVIDIA gamma control? I thought of adjusting the gamma control of my computer and I cannot find the setting controls, can you give me a step by step process or instruction to be followed so that I will be able to adjust it now? I hope you can help me.
Thank you.
How to configure nvidia gamma control?
On your taskbar (at the bottom right corner of your computer screen) you'll see a green colored eye-like icon there that's the Nvidia control panel, click it and a small window will appear from there choose Color Correction you'll find your brightness, contrast and gamma settings there adjust them to your desired values.
You can get the option while you right click the desktop as well. As shown in the screenshot.
rowansen
In Windows XP, Vista or 7 you can right click on the desktop, go to Nvidia control panel where you can adjust the gamma settings for your monitor.
You can click on the deferent menus the to adjust the gamma, brightness and contrast, digital sharpening etc to your desired choice. You can also go to Start, control panel, and click on the Nvidia icon to get into the Nvidia control panel. where can change the gamma settings of your monitor.
In Windows 7 when you open control panel and it is in the default view, you can change it by clicking in the right hand corner on category and choose large or small icons. this will display the control panel menu with icons and a short description next to it. hope this is helpful.Â
