How to configure a router with the following?
Hi, I'm new to networking. if we have two routers can you teach me how to configure them. Details are below.
Destination: 192.164.1.0
Mask: 255.255.255.0
Gateway/Next Hop: 192.123.11.150
Mask: 255.255.255.0
Two routers can be used on the same home network, whether you would like to do it wired or wireless. It can support more devices or peripherals, and can simply hybrid any network setups. However, it requires a special configuration though. Its setup must have a good location to ensure its correct physical connection, and you should configure the IP (Internet Protocol) address and DHCP (Dynamic Host Configuration Protocol) settings correctly to make it work smoothly, and to avoid any connection issues in the future. To set up your two routers and have them configured correctly, please go to https://www.lifewire.com/connect-routers-on-a-home-network-818060Â for the step-by-step procedure.Â
