We are working with multiple servers, all of it with dual NICs. To provide connectivity between the servers to the firewall LAN interface, we are currently using a single unmanaged switch. We have two Dell 3524 switches and two SonicWall NSA 4500s. How should we set up the two switches and how should we connect them? We want to be covered just in case one of the switches or firewalls go down for any reason. Any help would be greatly appreciated.
How to configure two 2 Dell 3524s to provide redundancy for servers
From what you described I believe you would like to perform link aggregation and you need assistance with the configuration. Here is a sample general configuration guide for one switch:
Manual aggregation mode
a. Create group 1
b. Add ports to group 1
Static link aggregation control protocol aggregation mode
a. Create a static link aggregation group 1
c. Create layer 2
d. Add ports to layer 2
e. Create a dynamic layer 2
f. Add ports to dynamic layer 2
Repeat these steps for each additional switch
