How To Connect To AT&T U-Verse Router?
I have purchased a router from AT&T. It is a box like structure with no antenna. How can I connect to AT&T U-Verse router using my laptop with wireless adapter?
To connect to AT&T router of U-Verse model you need to have an Ethernet cable that will be provided in the router box. If you have misplaced it, you can use any other Ethernet cables or even buy it from any reliable store. The router is not a Wireless router and hence it does not require to your device to have a wireless adapter. Instead you won’t be able to use the router to connect to wireless devices.
The other end of the Ethernet cable when connected to the laptop will enable access to the router.
Notifications
