Hello guys,
I want to ask about on how to connect bbc iplayer to vlc player? Is there a way of connecting the two applications? I am very interested and curious about it. Give me a few detail about this.
How to connect bbc iplayer to VLC player?
BBC iplayer can be connected to vlc player by using iplayer PVR Manager.
To download get iplayer PVR Manager click on the link below.
BBC iplayer can be integrated with vlc player by using the above software.
To know more about the integration process click on the link below.
Thank you.
At first you must get a iplayer PVR manager and then you can use to browse and play almost any BBC iplayer program directly from VLC's playlist. You will get an automatically generated playlist for the program type you selected.
Valid program types are:
Tv
Radio
Live tv
Liveradio
Open the playlist in the vlc GUI and you will see all of the available programs. Just click on one and it will start playing after a few seconds.
