How to connect digital surround system to my PC?
I have Logitech Z-5500 THX – Certified 5.1 Digital Surround Sound Speaker System, but I don't have manual. How to connect it to my PC?
The Logitech Z-5500 THX 5.1 Digital Surround Speaker Sound system is a multimedia speaker that is a definitely a cut above the rest. With the 505 Watts of power with subwoofer, four satellites plus a quality center speaker, it delivers true surround sound.
Thus, I understand how totally excited you are to use your Logitech with your PC. Imagine the best sound while you are listening to the music or while you are playing online games on your computer!
Now to use it on your computer though, you must check first and make sure that your sound card is upgraded to the right specification. If your sound card is compatible with your Logitech Z-5500 THX 5.1 Digital Surround Speaker Sound system then you may start setting it up by getting a copy of the manual.
It has the:
