How to connect ethernet adapter in Samsung Galaxy?
My Samsung galaxy needs an ethernet adapter to be plugged in to the computer. But the computer cannot detect the Samsung galaxy mobile phone. I am using windows 7 32 bit operating system. Give me some solution,
Best Answer by Sharath Reddy
Answered By 0 points N/A #129614
Can you be more specific on the model of the Samsung Galaxy you're using?
Answered By 590495 points N/A #129615
I think you misunderstood the whole procedure when connecting your Smartphone to your computer. To make it clear for those users who wonder why their computers doesn’t detect their Smartphones every time they try connecting it. The reason why this happens is that, for computers to detect your mobile device or your Smartphone you need to install its respective computer software.
Your mobile phone has its own software to be installed on the computer. Without it the computer won’t be able to recognize the new device. Instead, it will display an “unknown device” plugged in to its USB port. The Smartphone’s computer software enables it to be recognized by the computer together with the functions and features of the application which is intended to be used on the Smartphone’s specific model.
To fix your problem, just install your phone’s software to your computer. If you don’t have it or your Smartphone doesn’t have any CD with it when you bought it, you may visit SAMSUNG then download Samsung Kies 2.0.
This software connects your Smartphone to your computer.
