How to connect FTP client to any Servers?
Hello
I tried multiple FTP clients (FileZilla is my main one typically).I tried connecting to multiple FTP servers, but still nothing. I attempted to connect with no firewall,I opened ports etc. etc.
This is what I get —
Response: fzSftp started
Command: open "root@192.168.0.152" 22
Error: Connection timed out
Error: Could not connect to server
Any suggestions would be great, as I'm out of solution right now
Answered By 15 points N/A #119371
Here following the successful login details in a hosing server. It may help you to fix your problem.
Status        :      Connecting to 31.170.166.131:21…
Status        :      Connection established, waiting for welcome message…
Response:     220———- Welcome to Pure-FTPd [privsep] ———-
Response:     220-You are user number 22 of 500 allowed.
Response:     220-Local time is now 02:38. Server port: 21.
Response:     220-This is a private system – No anonymous login
Response:     220 You will be disconnected after 3 minutes of inactivity.
Command:    USER u826017431
Response:     331 User u826017431 OK. Password required
Command:      PASS ******
Response:     230 OK. Current restricted directory is /
Command:      SYST
Response:     215 UNIX Type: L8
Command:      FEAT
Response:     211-Extensions supported:
Response:     EPRT
Response:     IDLE
Response:     MDTM
Response:     SIZE
Response:     REST STREAM
Response:     MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
Response:     MLSD
Response:     ESTA
Response:     PASV
Response:     EPSV
Response:     SPSV
Response:     ESTP
Response:     211 End.
Status:      Connected
Status:      Retrieving directory listing…
Command:     PWD
Response:    257 "/" is your current location
Command:     TYPE I
Response:    200 TYPE is now 8-bit binary
Command:     PASV
Response:    227 Entering Passive Mode (31,170,166,131,243,73)
Command:     LIST
Response:    150 Accepted data connection
Response:    226-Options: -a -l
Response:    226 4 matches total
Status  :    Calculating timezone offset of server…
Command:     MDTM DO_NOT_UPLOAD_HERE
Response:    213 20120330020205
Status  :    Timezone offsets: Server: -14400 seconds. Local: 21600 seconds. Difference: 36000 seconds.
Status  :    Directory listing successful
