mart cullen
10 points
Posted on - 10/24/2012
Hi
I have got a laptop from my uncle who lives in Australia. It has a slot to insert a sim card and also in has installed software called net connector. I don’t know what that is and how to use a sim to access the internet.
Help me
Thanks
How to connect to the internet through net connector with sim
Sim slot in your laptop is the slot where you can able access internet and the net connector is provide you web services and manages your connector server. In order to access the net of your Sim you must applied an internet connection like Broadband Connection or Wireless Connection. Hope It will help.
Thanks,
Hi Mart Cullen,
You can use sim card to connect to the internet all you have to do is purchase a sim card with internet capability. The settings and the internet cost is depends in your area.
Hello Mart Cullen,
Happy to assist you.
Your Sim card slot is working just like an external modem. Just think that you have got a USB Modem with your Laptop. First you have to buy an Internet providing Sim card. Then insert it in to the slot. And open the Net Connector Software. It will indicate you the signalization of your service provider. As the Net Connector Software of your Laptop it will show you a button to connect to the Internet. Some times you will need to choose the network manually or it will set by Software. Mostly you just have to click on Connect button. Then you will connect to the Internet easily.
I think this will helpful for you.
Thank you.
