Qaiser
Posted on - 08/19/2016
Hey all! So, it’s a little mischievous question. Actually, I have been challenged by one of my friends to crack his router’s password, and I know very well that I alone won’t be able to do this. That’s why I came here asking for the help of you guys. Can you tell me how to connect to locked Wi-Fi without asking for the security key?
g12345
How to connect to locked Wi-Fi without password?
In today’s world, we got the notifications in our phones for the nearby wireless networks. But unfortunately, only some of them are open and that too the public networks only. So, if you want to access someone’s private Wi-Fi, you can try the methods below:
1. Using Port Scanner:
 To use this, you need to know the victim’s IP Address.
ï‚· Open the Port Scanner App.
 Now, you can scan the IP Address of your friend’s router.
 Click on ‘Show List’, and check all the ports named 80, 8080, 8088. Save the changes.
 Now, input the scanned IP Address in the ‘Start and End’ option of the scanner.
ï‚· In the result, if the scanned port comes out to be 80, then you can access this network only if the default address has not been changed for this modem.
ï‚· Now, copy this IP Address and type it in the browser Window.
 On the login screen, enter ‘admin’ for both username and password field.
You can now access this Wi-Fi network.
2. Using Instabridge:
Instabridge provides more than3 million up-to- date
Wi-Fi passwords and hotspots onyour mobile phone.
You can unlock a new set of Wi-Fi shared by Instabridge community or get a key for all wireless networks in your city. It also Auto-connect to Wi-Fi that works and keeps you away from those that don’t.
This application can be installed from Google Play Store or Apple App Store.
