How to connect lotus db android version?
I need to connect my Lotus Notes database to view the all data of my company severed and from anywhere. I need to view that from my smartphone with Android OS. So, how can I get this connection with lotus db android?
Best Answer by Williams Eccleston
Answered By 0 points N/A #141575
Go to http://www-01.ibm.com/support/docview.wss?uid=swg27036866 on your web browser then fill in your Lotus ID and password in the user name and password fields respectively. Click “Configure Your Android”. This will download for you the Lotus Notes travel on your android device. After download, go to Home>> Applications>> Lotus Installer>> Agree>> Next. Enter notes.cc.sunysb.edu on server address then press next. Lotus will then install in your device. Click Install then open. Click on Activate to activate the device admin. Press on Finish to complete the process. You can get more information here.
Answered By 0 points N/A #141576
Hi!
I have a solution for your problem.
If you want to connect and view your Lotus Notes using you Android OS smartphone.
I recommend you downloading Lotus Launcher from Google Play Store.
The current version is 1.3.0 and it can be downloaded using Android versions 2.0 up to the latest.
To know more and to download.
Download Here Lotus Launcher 2.
Thanks!
