How to connect mobile and desktop remotely?
Connecting remotely to other computer is really simple as long as you have an internet connection. First thing you need to have is a software like Teamviewer or any software that has the same function with Teamviewer. You can download Teamviewer for free in this link. You can choose any of the platforms of your computer or a Teamviewer software for mobile phones. Once you have downloaded that software, you have to install it. Please make sure to download the application/software in your desktop.
Once you’re done downloading the Teamviewer, please go to your desktop and look for “TeamViewer_Setup” without the quotation mark and double click on it. Then choose the radio button “Install” and click the next button. Choose “personal/non-commercial use” and then click the next button. Then put a check mark on the two small boxes where it says “I accept the terms of the License Agreement” and “I agree that I only use Teamviewer for non-commercial and private use”.
Choose “No (default)” and then click the next button. Please wait until the installation of the software is done. Every time you will launch the software and someone will remotely connect your computer, please provide your session id and your password. Please take note also that you can only connect remotely to the other computer if that computer has also a Teamviewer installed.
For more info click the link below.
Hi Richard welcome to the techyv.com If you want to access your computer remotely you can use teamviewer or logmein. With this free software's you can connect to your computer at home or any where in the world. you can also use windows remote desktop but its more complicated to setup but result of use is the same as teamviewer.
