How to connect nokia 5130 to oxycube 2.1?
I have same problem with nokia 5130. The memory problem. I searched for solution and i got oxycube. When i installed it oxygen connection wizard popped and I selected data cable connection. There were four type of cables from which DUK-5/CA-42(fourth option) was most likely to be. Then I clicked connect button and after a minute it said "connection was not established". My phone was connected to pc via data cable and pc suite mode was selected. Can someone help me? Phone has only 1.4 mb free and shows a total memory of 4.7 mb.
