Jeremy Jack
30 points
Posted on - 10/04/2012
Hello experts,
How to connect Nokia USB for Windows 7 drive? Can you give me a picture any illustration that will possibly lead me on the correct installation and connection process of the devices to avoid any damage and misleading information that is why I am asking you experts.
Thank you.
In order to connect your Nokia phone to your computer, you will need to install the PC Suite disk that is included in your Nokia package when you purchased it. It is inside the box together with the manuals. This software will allow you to synchronize your data from your mobile phone to your computer or vice versa.
Find the Nokia cable in the box and then connect it to the USB port on your computer and connect the other end to your Nokia phone. Wait for your computer to automatically install it and then start synchronizing your data.
