How to connect Nokia x6 upnp feature in Media Player?
Hi, how can i connect nokia x6 upnp media player feature in a wireless network. How can i set up this connection. Someone please explain in detail.
Thank you
Thank you
The X6 does not support UPnP.
Check the connectivity specs of the X6 on the link below:
https://www.cnet.com/products/nokia-x6-00-smartphone-gsm-umts-series/specs/
I am sorry to say but The X6 does not support UPnP. Compare the connectivity specs of the X6 https://www.cnet.com/products/nokia-x6-00-smartphone-gsm-umts-series/specs/Â to something else like the N82
https://www.gsmarena.com/nokia_n82-2177.php
You'll see that the X6 page makes no mention of UPnP. Its Sad but its true, especially for a media flagship device such as the X6 is meant to be. But it does not support it,
Peter franklin
